1 - 7 of 7 Posts
i am hearing this sound whenever i start my bike its like a small "took, took" like sound when i touch the air box, i can feel it in there also on the puke tube i can feel the pressure there. Is this gonna be a concern? bike runs fine just want to know if this is normal its not a continues sound i can hear it probably on the interval of 3-4 seconds. I notice this sound after replacing plugs, changing oil.
pull the cover is.. Is it coming from the crank case tube or the intake????
Discussion Starter · #3 ·
Are there any tips on how to properly detect which one was making that sound ? i was touching the parts at the time i was looking for that sound and i was feeling something on the airbox and the puke tube like when it does that i can feel the vibration coming from it.
Well if it coming from the airbox, it will be coming from INside the box. If you are feeling a pulse of air from the puke tube, that air is most likely coming from the crank case vent tube or the intake. open the box and find out. Which ever it is will determine your issue. If its a vibration it could just be a loose fitting filter.
Could also be a wire or hose vibrating against it. Or loose mounting screw.
Discussion Starter · #7 ·
i will check that out thanks :)
Im fairly new at this so forgive my terminologies from what i observe it feels like its a sudden burst of air that was doing this on the airbox like popping it and causing this sound
since the puke tube was underneath it i can feel the air pressure coming out of the puke tube too when i hear that sound.
1 - 7 of 7 Posts
