A couple things I can't remember and can't seem to find the the manual. I have an 83 vt750c with stock carburetor and a few basic questions.
1 - When adjusting the set screws for the air/fuel mixture, does turning the screw in (clockwise) increase the air:fuel ratio ie a more lean mixture? Or vice versa?
2 - So I do remember that a lean mixture burns hotter than a rich mixture but maybe we should make sure I have that correct.
3 - And what about rpm's? If you lean out your mixture you should see a decrease in rpm's right? Since the choke makes the mixture rich and causes an increase in rpm's.
I find questions 2 and 3 to be counter intuitive (at least to me) because I would think that a hotter combustion would lead to higher rpm's.
Well thanks for the help!
