1 - 6 of 6 Posts
Hello all. Question for you. I started my bike today and first noticed my neutral indicator light was not on, and yes, it was in neutral :) I started down the driveway and noticed my odometer (digital) was blank and my speedometer was not registering my movement. My odometer was on when I started the bike. I checked my trip meter to see if I needed gas. It wasn't but a few moments later that the odometer was offline. Any input appreciated. Thanks in advance!
84 VT500C retro bobber
First thing I always check when dealing with electrical problems, does it have power and does it have ground. That will immediately tell you whether its a problem internally with the component or an external issue such as a blown fuse or bad ground.
1983 VT500C, 1985 parts VT700C
If it's both its usually a fuse...it'll usually be the last fuse you check ;)
But it also might be one of the wires...squirrels/etc love wires...
Discussion Starter #4
It was just that, a fuse. Replaced it and all was well for a bit, then that fuse blew. So I guess it's doing it's job. My guess is I have a short and some exposed wire making an inappropriate ground or a nearly fractured wire making some contact, sometimes. Does that seem reasonable?
Yep, reasonable.
Here's where you get a $10 multimeter and learn about the OHMS setting ;)
Watch a few Utube vids, or grab an old Navy AE from the neighborhood...
The other option is to trace all the wires going from that fuse physically by sight
until you find the problem...but a multimeter finds it way faster.
Reactions: CSRoad
1 - 6 of 6 Posts
