1 - 16 of 16 Posts
I am a new owner of a 1983 Honda Shadow 750. This is my first bike that I've ever had so I have no experience repairing them either. So I got it home yesterday and had to jump start it because it had a dead battery. I know that it needs a new battery since this one won't hold a charge. I knew it when I bought the bike. So anyway, I jump started it, got it running and started riding. I went back out today to another dead battery. The difference is today when I hooked up the booster to the battery, the engine started cranking over. They key wasn't on or even in the ignition. I'm assuming that something is shorting out but I don't know where to start looking. I'm not sure if it is a cylinoid or what. Any ideas?
Get a hold of a service manual...that will have wiring schematics in it that will help greatly.
I'd check the ignition switch first....and the emergency cut off.
Good luck....and welcome to the forum.
Quit fiddling with a dead battery. Get a service manual and new battery, clean all your connections when you install the battery, and try it again. That way when you post again, we're all starting in the right place. Riding on a dead battery is just going to leave you and the bike stranded. Oh and BTW, welcome to the zoo.
2001 Valkyrie I/S
Sounds like the PO rewired it for you.
1998 750 ACE
I just recently replaced the starter switch on an 05 Ultra Classic for a fella which had similar symptoms as yours, but his would run the starter when he switched the bike to ON...
Harley doesn`t have "fixable" starter buttons though...
Switch Cleaning 101 tech sticky is your friend!
I truly suspect your starter relay/solenoid as your culprit though...
When diagnosing you aughtta start off with a KNOWN Good Battery...
Welcome to the zoo ;)
Merry Christmas
Ann & Dennis
Discussion Starter · #8 ·
I have found out, doing research, that it is most likely a starter relay. From what I figured out, these have the 2 leads coming off of it that go up to the starter switch. When you push the button for the starter, it makes contact inside this relay. When these go out, it basically bypasses the starter switch, therefore, it acts as if the starter switch is pressed non-stop. I'm going to get a new battery and this relay and I should be back on the road.
1998 750 ACE
You might diagnose that symptom by disconnecting those starter switch connections you mention, temporarily...
It's more likely the contact in the start button is the culprit. If it was the starter relay contact, the bike would be turning over with the key off. I would service your starter button after you replace the battery.
1998 750 ACE
The problem is that the starter kicks in as soon as the power is hooked up to the battery. With the key in my hand, the starter should not be turning the engine over.
UNquote...
Reread this jpr ;)
:D
LLLL bring it over, I have nothing on the bench at present...
Discussion Starter · #13 ·
It does turn over with the key off...or better yet, the key in my hand before I even put it in the ignition.
1998 750 ACE
Again, I suspect the solenoid...
Tap it lightly with a SMALL hammer or heavy screwdriver handle, it MAY break the connection???
Just a remedy I`ve used successfully in this case of stuck solenoid...
Merry Christmas
Ann & Dennis
1 - 16 of 16 Posts
