I just added hard bags to my 1994 Shadow VT1100C which facilitated the removal of the rear signal lights... I had prior to this replaced the front flashers with crossfire led bulbs and clear lenses,,, and I replaced the flasher relay with a solid state relay for led lights... all worked great... I added two led orange signal lights I got from advanced auto... when I turn on either the left or right flasher,,, all 4 signal lights flash... If i remove the new flashers and plug the stock lights back in,,, all is fine...
I would be easy to just run regular bulbs in and they would work fine... The flasher relay said it was good for all 4 corners...
Any ideas on why this is happening???
Thanks
Russ
Thanks
Russ
