You are shifting too gently on the pedal or too quickly on the clutch or a combination of the 2.
I always wear boots. I have a pair of Harley boots I've had for years. Huge, sturdy, up over the ankle, zip down the side.Wear Boots while riding is a good safety instruction,...
There is a reason behind it...
When I wear other shoes I miss gears too...
I`ve been known to "test ride" after working on mine and it is common fer me to miss gears as mentioned...
I haven't had this bike long and it's my first bike. I can do some maintenance myself, but I would prefer to have a professional give it a good lookover before I ride too long. I bought it on craigslist knowing absolutely nothing about bikes. So yes, I will pay the mechanic $200 to change fluid, inspect hoses, brakes, bearings, clutch, etc.Do the **** 16000 service yourself. Why would you pay $200-$300 for an oil and fluid change, if they even do that much.
Could be. Previous owner told me oil was changed about 13k.Oil change could be in order.
Do you know how to do basic maintenance on a car. cause the only real difference is the number of wheels and the cage.I haven't had this bike long and it's my first bike. I can do some maintenance myself, but I would prefer to have a professional give it a good lookover before I ride too long. I bought it on craigslist knowing absolutely nothing about bikes. So yes, I will pay the mechanic $200 to change fluid, inspect hoses, brakes, bearings, clutch, etc.Carb sync and valve clearance? *blows my mind*
Yes it looks like you are due at 2400 miles. Changing the oil will probably help with the hard shifting.Could be. Previous owner told me oil was changed about 13k.
So did we. Guess we are old school......We always called that a false nuetral...
I can change the oil and the plugs and wires on a car. Air filter too. I'm sure I can do all those things on a motorcycle as well. I'm not real technically inclined, but I do want to learn. I just don't want to jump head first into everything. I prefer a little bit at a time.Do you know how to do basic maintenance on a car. cause the only real difference is the number of wheels and the cage.
