Picking up my bike on Sunday from owner. Bike runs well, idles great, and has good throttle response as well as a positive clutch feel. Bike has an estimated 30k on it. (Speedo is now off the bike since he made it a bobber, probably around 1 1/2 - 2 years ago).
The only issue I saw was a stuttering at WOT while riding quickly. If I gave the throttle a good pull the bike would move fine. The stutter or hesitation only happened on full throttle at speed. I'm thinking coming from street bikes, maybe the revs were too high for that gear? This only happened at full throttle mind you. I could rip through each gear and the bike would respond very quickly. Only if I increased to full throttle while riding at a pretty quick speed would it stutter (maybe hesitate is a better word).
I figured it could be plugs, bad gas, jetting, or air filter. Air filter is one of those velocity stack things. I'm trying to figure out what I need to replace it with a stock-like air filter setup. It has pipes on it, but not sure what kind and I believe it is stock jetting. Pipes still have baffles in it. Cruisers are very new to me so I have a bunch to learn.
Owner said he rides it all the time. Never had any issues with it and it has never left him stranded. From what I saw I would tend to agree. I've never had a bike with this kind of mileage on it before so i'm trying to figure out preventative maintenance for it.
I only have two or three weeks left of riding then it gets stored for the winter.
I plan to change oil, plugs(trying to figure out what kind), check coolant, clean and lube chain, check bolts, tire pressure. I will also be removing the tank in two weeks or so (when riding season is over) and take a look at the carbs. Anything I should look at checking or replacing this winter besides what I already mentioned I was going to?
Carbs as well as V-twins are all new to me. I'm capable of removing wheels, changing coolant and oil, but carbs are new to me as well as fuel and jetting.
I can get a video with my GoPro once I pick up the bike this Sunday.
