1 - 2 of 2 Posts
2000 VT1100C2 Sabre
I installed a GPS last year and all was fine until winter storage. Shame on me. I hooked it straight to the battery and it killed it.
What circuit do you recommend I hook a relay to that is switched from the ignition?
Your ignition switch wire with a 5 amp fuse and relay, if needed, then to the plug for the GPS should have no battery drain.
1 - 2 of 2 Posts
