1 - 8 of 8 Posts
First Post:
Took over Dad's 1992 VT1100. I'm sure maintenance was ok but not great. When I start the bike the temp light comes on and fades out and comes back on. Another time it never came on. Something faulty? or serious problem?
Discussion Starter · #2 ·
I read somewhere that it can be loose exhaust pipes. He also a quite a bit of popping during deceleration. I hear that is also a symptom. I will let you all know what happens.
1995 VT1100C2
I have never heard of temp light connected to loose exhaust pipes. More likely its time for a coolant change. Decel popping is typical for these and difficult to reduce. Either get used to it or try adjusting the A/F mixture.
G.
Mechanic said it is a temperature sensor problem. He says honda doesn't sell it anymore. I found a used one on eBay. I'll put it in. We'll see.
Honestly, I'm not very familiar with Shadows yet.
On the 4-cylinder Goldwings there is a fan switch (looks like a sensor but larger) and temp sending unit (smaller, like a sensor should be).
Both are discontinued.
Both have been paralleled through the automotive parts houses though.
I would guess that a similar resolution could be had here with this issue.
1 - 8 of 8 Posts
