Hi guys,
2 things on my mind.
1st - RPM needle on rev counter "flickers" from a nice idle rpm of 1000 then when I leave throttle alone, it'll dip quite low and back. It's consistent but never low enough to stall. On occassion it will dip a little higher then back to the idle of 1000rpm, but certainly regular low dips, especially after a good rev of the throttle. When I've rev'd it'll return to idle rpm but will dip under the 1000 mark before climbing back to the 1000.
2nd - Upon going for it for a burst, really nailing the throttle and giving it "the beans" for a zoom, it begins to "jugub jugub vroom jug vroom" and kinda sound as though it hasn't enough fuel or something when opening the throttle for a burn. Fairly great when going steady though.
I know with these carbs they will tend to choke a little when suddenly opening the throttle, just wondering if I may need a larger jet with that prob.
So basically...
1st RPM needle dipping
2nd Choking/slight cutting when opening throttle for a burn down the road.
Any ideas would be appreciated.
Oh yeh, it does start much better after Seafoam, but these issues were there before and after Seafoam so maybe I don't have something set just right.
So basically...
