What is the smart thing to do when you get a flat tire? If the puncture is just a simple nail in the running surface, can you have it repaired? Or, is getting a new tire the only reasonable thing to do? I assume that fix-a-flat is the wrong answer.
You have a VLX...right? Well, it has a tube. So...the best thing to do is either replace the tube or patch it. You can patch it like you used to patch your bicycle tires.Van said:What is the smart thing to do when you get a flat tire? If the puncture is just a simple nail in the running surface, can you have it repaired? Or, is getting a new tire the only reasonable thing to do? I assume that fix-a-flat is the wrong answer.
