So I just adjusted the AF screws to 2.5 turns, and the goddamn thing still is acting like this! The only thing I can think of is it's something with this jet kit or maybe the enrichner/choke is boogered up? Everything was fine before I did anything to it.
once you get it started, it's fine... it's just starting is too rich.
Checked the enrichner valves. Everything looks great and in adjustment.
This makes NO sense to me. Why would needles and a main jet cause everything to run so rich! My plugs are literally wet. I changed nothing in this process. Took carbs out, swapped needles and jets around, nothing else. Didn't touch the floats. Didn't touch the pilots. (except the AF screws, which were about 2.5 turns out and still capped off). If anything, you would think I'd be running lean...
