1 - 4 of 4 Posts
2004 Honda Shadow Aero 750
Hi everyone.
I took advantage of the great weather yesterday to winterize my 2004 Shadow Aero 750. When I filled up the tank, I noticed that the gas level kept dropping to about 3” from the opening. I couldn’t fill it to the brim.
I am wondering if this is normal, if there is an overflow valve of some kind? I didn’t notice any leaks or fuel on the ground. My question is, should I keep trying to top it off or have I reached the limit?
Thanks!
sage
Ok, after posting, I saw this had been answered already.
cheers,
sage
04 shadow aero
If you poke a hole in the tank tube it’ll equalize faster. Don’t fill it up to the top or it’ll block the vent hose and stall the engine
Yup, the infamous Neck Filler Mod.
use a BRASS punch, HF for a couple bucks.
YUP!!
I done it!
BUT > I drilled mine :D
(Yes I used a magnet to catch the shavings)
&&&&& >> Don’t fill it up to the top or it’ll block the vent hose and stall the engine
It`s an 11+ miles trip to home from the gas pumps & I ain`t had this problem, not once...
We RIDE!
SO > I gotta get as much fuel in there as I possibly can!!
I switched to RES @ 140 miles today, and filled it as full as I could,
Dennis
3.5 gallons 152 miles = 50MPGs :D
1 - 4 of 4 Posts
