Can you mount that radio shack piezo buzzer for turn signals on the outside of your headlight towards the bottom or will rain ruin it if it gets wet?
thanks
2008 shadow areo
thanks
2008 shadow areo
It's supposed to be annoying. So that you turn off the signal.:shock:I had a radio dhack one mounted right where the flasher relay is. It was there for one season the ripped out without prejudice. It is the most annoying (to you and others) mod you can do. Install a light the buzzer is just WRONG.
If you were going to wire up a buzzer, then it would probably be best to also wire in some sort of timer for the buzzer so it doesn't start going off right away, but waits an appropriate amount of time. That way it's more likely to actually be a reminder for when you forget to turn them off and not so much of an annoyance buzzing the whole time your turn signal is on.That would make me crazy while waiting for a light to change. :evil:
Whoa dude, I gave you a constructive and creative alternative with the mirror LED thought ... nobody's knocking you, we're just having fun. No harm done. :-DWow i thought this was friendly motorcycle site. I never would have thought that buy asking a simple question i would end up with such S A responses from fellow motorcycle riders.
As far as it going off the whole time your stopped it does not as i hooked it up to a relay so when the brake is on the buzzer is silent .
i guess i'll just have to find a forum with serious riders.
