1 - 20 of 29 Posts
Ok, got my lights re-wired and The front LED work with the rear lights not plugged in. The rear lights don't come on at all. parking or turn. I don't have the brake light on yet. Checked all the fuses and they are good. I can't seem to see what I'm missing.
Sounds like you may have them wired incorrectly. Check the wires coming back to the rear signals and see if you have power to them. If so, rewire the rears and try again. Are the rears LED also?
Discussion Starter #3
At first yes it was bulbs in the back. Just picked up some LED signals for the back. They light up but they don't split left or right. Just on or off
Is that to say you have running lights, but no rear turn signals? When activated do the fronts blink, but not the rears?
Discussion Starter #5
Currently the front LED signals are lit up like parking lights. They flash when activated. The rear LED signals do not light up like they are parking lights. When activated either left or right, both rear signals flash.
I think you've got wires switched up going to the rear signals. Maybe you're feeding power to the ground wires of the rear signals?
Discussion Starter #9
I've been following my wire diagram. As best I can tell its accurate. Green to ground and light blue and orange to positive.
Some here who have gone to LEDs have had to install a diode for them to function properly. My rear turns are the only bulbs that haven't been switched, just to avoid that situation. When I installed LEDs in my front running lights I had hyperflash, but fixed that issue with a 2 wire electronic flasher unit.
The front LED turn signals aren't supposed to work with the rear lights not plugged in. Go over your wiring and try to find where it's wired up incorrectly.
Try wiring a couple couple hundred ohm resistors, one each, in series anywhere in the right and left turning bulb circuits. The LEDs probably have insufficient resistance to trigger your flasher unit.
it's odd that you're not getting 4-way flashing (hazards) on the front signals too, or are you? The 4-way flashing issue can be resolved by pulling the indicator light bulb on the dashboard.
Discussion Starter #19
Had a slight break through from a chance video on youtube. Basically it boiled down to, the turn signal indicator light was a bulb and it was screwing up the LED's. Removed the bulb and the light all work fine now.
Discussion Starter #20
Took the LED signals back to cycle gear. Asked if they could check them so I can see if its on my end or the lights. They grabbed a battery and the light lit up completely. While on my bike it only had 3 or 20 lit up. Ordered some resistors, we'll see if that fixes the issue.
1 - 20 of 29 Posts
About this Discussion
9 Participants
RONW
Honda Shadow Forums
Full Forum Listing
