1 - 5 of 5 Posts
Not sure what’s going on. Maybe someone has had a similar problem. I have led turn signals on rear so I wanted to change the front signals to led. Bought a converter kit plugged them in all good they flash and stay on as normal. But the indicator light on tank stays on solid and doesn’t flash as normal. I have a load flasher relay. Do I need a separate one for the front? Honda aero 2007
With a single bulb on the dash the LED system can back feed from both sides, so it needs 2 diodes to separate the sides before the dash bulb.
Here is a source or make your own easily .
Reactions: Kenstone
Or maybe replace the indicator bulb with a LED?
1 - 5 of 5 Posts
