I can't figure this out. I've dissassembled the turn signal switch assembly, cleaned all the gunk, and lubed it back up with dielectric grease. I've put it back together and...it's still very stick.
When I try to turn on the blinkers, it's like the little metal piece with the contacts that slides the plastic piece doesn't slide it far enough in either direction. I can only get the blinkers to kick on if I reach in with a screwdriver and slide them all the way to the left/right.
After I move it left/right, it doesn't pop back to center. When I press it in, it also doesn't pop back to center.
When I loosen the screw holding the metal piece with the contacts, it doesn't help very much. Does that screw in the center need to be TIGHT, or just barely tight enough?
