Just got my 85 Shadow VT700.
Front left signal stops working if the right signal is used.
Problem on my 85 VT700.. Front turn signals.
They both work as blinkers, and the front right always works as a running light.
But the front left sometimes works as a running light and sometimes doesn't.
If i turn on the right blinker, when I cancel the blinker, the left light goes off, But if I turn on the left blinker, then cancel it, it stays on as a running light.
Basically the front left stops working as a running light after the right blinker is used..
I changed both bulbs.
Is this a switch issue or a ground issue?
