I have a 2001 1100 Spirit. I have trouble with the turn signals when it's cold out. This morning was a case in point. When I first started, the signals would not flash. When I turned either signal on, that light went dark, and would not flash. Turning off the signal brought the light back on steady. After about 10 minutes, the signal would start to flash after it had been on for about 20 seconds. By the time I got to work 30 minutes later, it was taking about 5 seconds to start flashing.
Has anone had a simlar problem. I've cleaned the contacts (by spraying contact cleaner in there). I haven't taken the switch housing apart.
The problem doesn't manifest unless it's below about 45 degrees.
