1 - 8 of 8 Posts
So I had to rebuild the slave cylinder. Watched a few videos, and seemed pretty straight forward. After taking it apart, it was clear what 10 years of sitting can do to the inside of the mechanism. I was cleaning the crap out of cylinder in the bike and noticed there was a spacer with a cut out moving around. I was able to pull it out, and realized I never saw this piece in the videos. It sits between the piston and the rubber seal going into the crankcase. When I was cleaning it, I notice what I thought was grease was on the back of it. Anyways, I can't find it in the rebuild section of the manual. So anyone know about this part? Does it need to have some grease applied before I install the rebuilt slave cylinder? It looks like the cutout on this spacer lines up with a notch in the cylinder on the bike. Sorry I don't have pictures now, but can get some later today
Yes 10 years of OLD FLUID will gumm things up...
We change fluids @ 50,000 regardless !!!
OLD Fluids cause damage!
I`m Proud to Ride HONDA!!!
D
166,000+ on the clock
Probably a support or guide plate for the rod I would imagine.
Or a piston stop?
Discussion Starter #6
Or a piston stop?
OK makes sense. Would something like this need grease? I can't imagine why, but when I took it out and cleaned it, it looked like there was some grease on it. This would be on internal side of that guide plate, not facing the piston.
edit: perhaps to a touch of grease where the rod goes through?
They may have put grease on it to hold it in place while assembling the slave so it doesn't shift out of it's groove. I have done that many times. A touch of grease on the shaft would be good too.
Discussion Starter #8
Once again you the man!!! Thanks for your help!
1 - 8 of 8 Posts
About this Discussion
3 Participants
jmsanch
Honda Shadow Forums
Full Forum Listing
