Hello again!
So after the electrical fiasco -which everybody was a great help about-, I came to find out after inspecting wiring behind the frame covers, I decided to check radiator fluid...to my surprise it was bone dry! I flushed it out and all sorts of crap came out from it sitting.
Well, of course since it sat empty for a year the seals which were already old, dry rotted, aged and/or were ruined by overheating! When flushed & refilled It leaked from the rear upper water pump hose, crossover tube, AND upper cylinder head tubes in no time! :x
1) So far I RTV'd the slow upper water pump hose leak(where it connects to the rear cylinder on the bottom?) Thumbs up! No problems here.
2) I ran to Home Depot and acquired some O-Rings and SOMEHOW with a bit of frustration, all alone, dental flossed between it's crevices until that darn sucker slid onto its tubes! Bit of advice, use a coat hanger. Thumbs up here! (PITA :lol
3) Then the upper tubes leaked, I managed to tear down the carb intakes and all that stuff, loosened the bolts that fastened them down, and learned you can push the tube forward and drop it down slightly which allowed me to pull of those crusty dry seals.
My question is...how the heck am I supposed to slide these seals back on? The tube is wider at the bottom so I have to slightly stretch it over the tube while managing to hold it in place and squeezing my hands in a tight space! If I lube the seal with oil or anything it slips around LOL...there HAS to be a simpler way to do this WITHOUT dropping the friggin motor!!! :lol:
