Arrgh, Help. Valve adjustment gone wrong?
I followed the valve adjustment instructions in the Honda Service manual, but when I got everything back together, there was loud ticking from the engine. I took everything apart and repeated the process at least 5 times. Before the maintenace, my bike was running and sounded fine. I just had a lack of power on the low end (wanting to stall in 1st gear and lurching). When I checked my manual, I knew this maintenace had not been done in years.
Here is my step-by-step, please tell me if you see anything wrong. This is on a 1983 VT500C.
- Open timing cap and turn shaft clockwise to align line next to FT with index at bottom of view hole. I attached a photo to make sure I'm correctly aligning the marks.
- Opened Intake valve cover on the front cylinder (it was late in the process before I finally saw in the manual that there are also exhaust valve covers).
- Checked gap with 0.004-0.006" feeler gauge (I bought the "Go-no-go" feelers that have a range listed)
- No gap between adjuster screw and valve stem on either intake valve. I loosened the nut, backed out the adjuster and set the gap of I could get the 0.004-0.006 feeler in, but not the 0.005-0.007 feeler. I did this to both intake valves.
- Turned shaft to align the line next to RT with the index.
- Checked intake valves on rear cylinder. Found them with no gap as well. Had to back out adjuster screws "a lot".
I put everything back together and was pretty proud of myself for figuring out the adjustment process. But, when I started the bike there was loud tinging in the engine. I think from both front and back.
As stated above, I readjusted following the same steps at least 5 times. When readjusting, I found the gap a little too tight or a little too loose. Occasionally, I did not have to adjust one of the intake valves.
Here are a couple observations and comments that may allow you more experienced guys to steer me right:
- I noticed that when I turn the crankshaft past the F||, to F| mark, the rocker arms start their downward motion to the valve shaft. When I get to the |FT mark the rocker arms have moved down a bit. It seems to me that any slight difference in my aligmnent of the FT mark with the index would produce a different gap.
- The manual indicates that I need to make sure the piston is at TDC. How do I do that other than to align the FT mark with the index?
- I checked my Clymer service manual when having trouble and saw the photo for the ehaust valves. So I had only been adjusting the Intake valves. I opened the front exhaust valve cover and noticed the valve it stayed tight with no gap. Would the bike start making noise if I correctly adjusted the intake valves but left the exhaust valve with no gap?
Please let me know where I've gone wrong.
