Morning!
Firstly, the bike is a VT1100C Spirit, vance and hines pipes.
I was out on Sunday, With the mrs on the back, bike was running great, all be it, I had to stick it on reserve to get it going in the morning as i'd forgotten to go for fuel.. but after that, I'd done around 50 miles riding then on our way home, I got up to around 95 mph, and the bike sort of died, slowed right down as if i'd ran out of fuel, then kicked back into life.
Now I can get up to around 95 mph, with a bit of work but no higher, which is a ball ache! I've been over my usual stuff, vacuum hoses, air filter blocked, carbs are tight, and clean, plugs are fine.. but what I have noticed a few things that could be causing a issue;
Fuel filter looks older than me! ... I'm presuming if I lay down and look under the bike, by the rear arm, its held on by a clip either end, looks like it could be fiddly to get out? if that's it, i'll change it anyway!
also, the tank, it has a outlet on the right hand side looks like a hose should go on it? now its blocked from when I had my tank painted, BUT, its never had a hose on it, and the bikes ran fine for months before now, just wondering, being in England, and having a California model spirit, should it have a hose on there or anything?
lastly, which I'm going to try on my lunch, I increased the A/F mix by a turn and a quarter to eliminate popping and banging on decel, could that have caused it?
if anyone has any advice, it would be great, cheers!
