According to the official Honda Service Manual there is no adjustment. If the cam chain is worn/stretched, it needs to be replaced.
Here is a direct quote from the manual: "Measure the amount of the cam chain tensioner projects as shown (there is an illustration). Replace the cam chain with a new one if the projection exceeds 9.0mm (0.35 in)."
You need two chains and the part is obsolete. Here is some info from partzilla.com
2
14401-MF5-004
CHAIN, CAM
$157.80 $157.802PART OBSOLETE
14401-MF5-003
CHAIN, CAM
14401-MF5-000
CHAIN, CAM
14401-MF5-013
CHAIN, CAM
3
14510-MF5-772
TENSIONER, CAM CHAIN
$106.44 $106.442PART OBSOLETE
The 83 & 84 Ascot share the same engine as the vt500c. It may be easier to find the parts in the UK than in the USA.
If it is just a little noise try to live with it.
Good luck,
Chuck
