Hi, I have a 1983 VT500 and I noticed that the plug was missing from the engine breather tube so I fitted a bolt to blank it off - I am just wanting to make sure I have not done something wrong as a remember reading that the engine must breath or you can have problems.
I have looked at the parts diagram and see that the engine breather runs to a catch container which holds and water and this is then drained via a drain tube with a plug at the bottom.
Could you let me know if the catch container is supposed to vent back into the air box as mine has a bolt in this location. I am thinking that the PO blocked the air box vent to prevent the oil / gases coming back in and then vented the engine using the drain tube.
I have been working on the bike and have gone for a few short rides and have found the bike just die after a quarter mile and after a few minuets it will then restart - a past thread suggested that the petrol cap vent may be blocked. I am going to test this by running with the cap open but do not want to run until I am happy that the breather is right.
Hope this make sense to some one. Thanks Andy
