85 shadow vt500c
I have a vt500c and one cyl is not firing. I tested the coil and its supposed to be 2 ohms and it is. i tested the wires that go to the coils while it was running on one cyl and the firing coil is getting intermittent pulses to the yellow wire. the non firing cyl is getting a constant 12+/- volts. it is the same as when the key is just in the on position. I have removed the cdi and am slowly carefully removing the old glue to see if a diode is blown or if i can find a problem. does anyone else have any other ideas? Also, let me know if you have a cdi for a 85-86 shadow vt500c. Thanks for the help.
Andrew
Andrew
