1 - 3 of 3 Posts
Hello All,
It was a bright sunny day a couple of weeks ago and I mistakenly left the ignition of my 1988 vt800 in the on position. I charged the battery and tested it, but I still have no power. The main 30A fuse has also been tested.
I suspect it's the ignition switch that's possibly fried.
Does anyone know:
1) How to test the ignition switch?
2) If I need to replace the switch, is there any other model year ignition switch that might also work?
Thanks.
Hello All,
Does anyone know:
Thanks.
Check all your fuses. at the ignition you have one hot wire from the battery (should be red, I may be wrong), the others comming out will have power with the key in the on position.
Discussion Starter · #3 ·
I get no power on the "hot wire" to the switch; however, all the fuses checked OK.
Does anyone know if the "hot wire" comes directly from the battery.
I get the expected 12+ volts at the battery and at the relay switch (where the main 30A fuse is located)
Thanks.
1 - 3 of 3 Posts
