1 - 8 of 8 Posts
So when my VT-1100 Sabre gets warmed up:
Still has great throttle response.
Does not miss a beat riding and idling.
New plugs; put in after the issue started.
When slowing down the bike does not backfire so the seals seem good.
I did add some Seafoam after the sound started, we'll see what happens after running this tank of gas down...
When at normal running temp there is a sort of popping sound. The sound is not consistent with the idle, it'll pop a few times stop, pop once or twice stop the pop several times..... Sounds almost like a circuit opening and closing or a some sort of valve....
The bike is not a California model so I ruled out emission equipment. I have not taken the tank off to check for crimped hoses yet.
Anyone come across anything like this?
Try unscrewing the idle mixture screw out 1 turn to see if that changes anything. The fine tune from there.
Reactions: Scuba77
Discussion Starter · #3 ·
I'll give it a try. Bike will be at operating temp when I ride it back from work today.
Discussion Starter · #4 ·
Well, tried it and so far a no-go so far. Will ride it a bit and see if it changes.
Thanks for the idea though.
Can you feel a miss in the engine when it does that? Could be a possible carb slide/diaphram problem, If one side has a gummed up needle and is sticking it can have a random muffled popping back through the intake. Gets bad enough it will cause rideability issues...
I pulled the air intake and watched the slides, right side not moving with left, would stop openingpop, then jump open. could push the slides up manually and feel a sticking spot in the right slide movement. Pull the carbs and cleaned the crap out of them, (twice,,,) and it cleared up
Reactions: Scuba77
Discussion Starter · #6 ·
Nope, doesn't miss. I was talking to a friend and he mentioned it could be the air injection valve. However I did notice yesterday a slight amount of gas coating the carb that feeds to the rear jug. Will be taking it in to a local mechanic after looking at the illustrated parts breakdown, I'm more rider than tinkerer.
being an 1100, the small miss may not be felt. It was noticable on the 750 especially after it got worse. Good luck with it, Sometimes, that's the quickest and least expensive path...
Discussion Starter · #8 ·
OK popping solved.
The sound was actually coming from the fuel pump pulsing. The bike ran great until about three weeks ago when it started to act up like the tank breather hose was plugged. Decided instead of ripping the bike apart and replacing the hose maybe the fuel lines, just bring it in.
Long story short: fuel pump was going bad. My local shop, Metrix Motorcycle Repair in St Augustine, replace the pump and since he had rebuilt the carbs a few months ago, rejetted them for no extra charge. The bike pulls and runs great now.
1 - 8 of 8 Posts
