1 - 6 of 6 Posts
i have a 2006 shadow spirit 750. when i turn on my ignition nothing happens. as in no headlights, indicator lights etc.. and the battery is new and charged. any ideas?
Welcome to the group!
Have you checked the fuses? There's also a main 30 amp fuse that's not in the same fuse block. Follow the positive (red) wire from the battery and you'll find it.
--Justin
Justin is spot on. Common problem. I keep extra fuses in the tool bag. Come in handy.
Check your main power fuse, they burn out sometimes. And check your other fuses as well. Trace your battery cables to verify they are hooked up correctly. I had the same problem a while back and it turned out to be a loose connection under the seat (not the battery cable though, it was some other wire).
If these don't turn up to be your issue, then it's probably time for a multimeter and some trouble shooting.
1 - 6 of 6 Posts
