Hi all!
Bit of a situation here and if anyone has any thoughts that might help!
Starting off, I'm the 3rd owner of this bike so the rats nest of wiring was inherited, as is any other changes noticed!
Bike was initially cutting out in damp/wet weather (light mist, fog, light rain). The display (odometer, indicators) would cut out and then the bike would run rough and die. After this last round I let it dry out in the garage and started it up. Was running fine then suddenly died out. Began to notice a slight burning plastic smell. Pulled off the seat to find that the connections pictured were smoking a bit. Found a few other wires that were loose, cracked, and or not connected. Taped and replaced what I could. Service techs at the local Honda Dealership said to just not worry about the new quick connects and run the wires together (yellow-yellow for all 3, red to red, green to green). Have it all back together and now when the ignition is turned on there is no response. Dead bike.
Any thoughts or need more info and pictures?
All help is appreciated!
