Cobra Drag Pipes - baffling options
4.7K views 6 replies 6 participants last post by  Phil
#1 ·
As I've posted elsewhere, I bought a Spirit that came with Cobra drag pipes, and they're much too loud for me, and Cobra does not manufacture a quiet baffle for the drag pipes. Does anyone have any advice for how to make these pipes quieter? I'm not a mechanic and I don't have a garage of my own, so I'd prefer to purchase something pre-made I could easily install, but detailed instructions on modifications would be fine too.
#2 ·
Wear earplugs. >:)
Seriously. Have you checked the packing on the existing baffles? You may want to start with repacking them. If still too loud, check for other than OEM baffles designed to fit. Then there are lollipops.
#3 ·
Do you know of any non-OEM baffles designed to fit Cobra drag pipes? I haven't found any.
I don't know anything about repacking and lollipops, but they seem like options for people with the skill and equipment to manufacture their own solutions, which doesn't work for me.
#4 ·
If they are true drag pipes there will be nothing in there for a baffle or anything.
What you could do would be to measure the inside diameter of the pipe and then start doing research on baffles from different manufacturers. Most of them are held in with one or two screws through the pipe into the baffle.
#7 ·
I used to have Cobra Drags on my 750ACE, not only were they loud but they sounded brash and tinny. I put a pair of "HP Plus" baffles in them and got a much improved tone.
With the HP's they only get loud when you lay into the throttle and the tone is more like a deep rumble, not so tinny. Plus they'll help improve low and midrange power because they produce more back-pressure.
The only downside is they're expensive......
Phil
https://www.jpcycles.com/product/440-625/khrome-werks-hp-plus-drag-pipe-baffles
