I'm working on a bike with 28,500 miles that apparently has not run for 7 years, meaning since 2018. During that time, it was neglected, not maintained at all and only sheltered from the weather by an open tarp shelter, which gave critters and insects full access to make the machine their home. I have "deloused" and cleaned the bike, as well as completed repairs and replaced parts with the objective of just getting the engine running. I have replaced the battery, fuel pump relay, fuel pump, spark plugs, engine oil, oil filter, air and sub-air filter elements, coolant, and the radiator fan temperature switch. Last, the carburetors were disassembled, cleaned, blown out and rebuilt with new O-rings, new float valves/seats/filters, new main jets, new needles, and new pilot screw assemblies. The air cut-off valves, bowl floats and vacuum chamber diaphragms were checked for holes, with float level set to 7mm. The choke system was freed, cleaned and lubricated. It consists of a cable-operated STARTING ENRICHMENT (SE) VALVE on each carb, spring assisted to close, with both cables spliced together to permit control by one pull knob.
So….with the carbs reinstalled using new insulators at the intake ports, the engine does start, however only the spark plugs in the #1 (rear) cylinder are firing. The plugs in the front (#2) cylinder are not firing and unburned fuel is being sucked into the combustion chamber where it is pushed out by the exhaust stroke. That fuel then washes down the inside of the Vance & Hines exhaust pipe, with it then both dripping and spraying out of the end baffle, in large quantities. (BTW, I checked the compression on both cylinders and got 152 psi for both cylinders.)
To check the ignition coil for the front #2 cylinder, I switched the rear #1 coil with it, but the problem stayed with the front #2 cylinder. The continuity of the wiring between the IPG [ignition pulse generator] and the ICM [Ignition Control Module] was confirmed OK. The continuity of the wiring from the ICM to the primary side of the ignition coil for the #2 cylinder was also confirmed, as was the continuity of the secondary windings. To me it appears that, unless the pick-up for the IPG is faulty, which I doubt because it is working fine to generate spark for the rear #1 cylinder, then the ICM must be malfunctioning. But I can't find a procedure to confirm my suspicion.
If anyone has any insight to this problem please let me know.
