They don't make a jet kit for this bike, but if you want to open it up a bit, the main jet is a #112, and the slow jet is a #42 (I think.)
The "poor man's jet kit" would suggest you replace the main with a 115, and the slow jet with a #44 (If it's a #42 to begin with.) Keep the stock needle. it's not as good as a Dynojet variable-taper needle, but it's good enough.
These numbers should be close enough, but depending on the exact characteristics of your intake and exhaust, you could tune them a bit more. Also, open your idle jets to 3.25 turns, if you haven't already.
Knowing that the carbs are such a bear to get off this bike, the amount of tuning that you decide to do may be limited!
--Justin
