best home made tool for front forks disassembly
12K views 4 replies 4 participants last post by  wannabridin
You may not need anything special. Often times it will spin right out if you use a small impact driver. Pro tip: Remove the piston screw first. Pressure from the fork spring will tend to hold the piston in place. When that won't work, I have used a wooden dowel (broom handle) to hold the piston. Worst case, if the screw is seized or has Loctite on it you will have to drill the head off of it.
Sent from my iPad using Tapatalk
