Lets get a discussion going regarding the tricks of Emergency Braking.
I believe there are two basics to this. Straight line breaking and braking on curves. Very different scenarios.
Obviously we need to use both brakes to stop as fast as possible. I know very little about this so here are a few thoughts straight from my @#$.
Straight line breaking.
- Too much back brake will lock the wheel and your slated for a front over crash. Wheel slides past the bike on one side.
- Too much front brake and you lock the wheel and over you go as well right?
So what do you hit first? Second? Recovery?
Braking on curves. Same issue as straight line breaking except you go down sidways if the back wheel locks up. What happens if you lock the front wheel on a curve?
Straightening out the bike and then braking on a curve can lead to front overs in addition you may drive into something unexpected.
Thoughts?
Thoughts?
