Forward Controls Installation Help
733 views 2 replies 2 participants last post by  juanitolapaja
#1 ·
I follow the instructions and everything installed fine but the last thing i was doing was installing the longer brake rod, the front part where it connects to the brake pedal was easy but the back is a little more complicated and here is where i need some help.
I took the safety pin out of the back screw easy, next i took the 10mm nut out but when i try to slide the screw out there doesn't seem to be enough space for the screw to slide out; it doesn't matter in what position i but the brake rod there is just not enough space.
Have anyone of you guys done this before and can give me the tip i need to finish installing this forward controls, thanks in advance. :?:
#2 ·
You will need to remove the support rod on the front of the brake plate and rotate the brake plate to remove the rod.
Hope this helps.
Joe
