Reserve Tank/Petcock
385 views 8 replies 5 participants last post by  "Captain D"
#1 · (Edited)
Forgive me if this was answered before*
I just replaced the petcock valve on my 600 vlx (2007)
The petcock only has one long straw as apposed to both a long straw and a short straw. Every petcock replacement I've seen online all have one straw, specific to my bike year and model.
Am missing something? It appears the lever only has two functions. Sitting on the bike as a point of view, if I turned the selector all the way back towards me, it shuts off. Turning all the way forward, it runs. Half way, it just sputters and runs weird until it stops.
Help me Obe Won, you're my only hope.
#7 ·
If reserve isn't working with a brand new petcock, maybe you got a bad one with flash inside the casting blocking that passage.
Or, the seal at the bottom of the in-tank filter is blocking the reserve intake.
Here's a look at what is inside. If yours is assembled with screws, you can take it apart and investigate.
Do you see how it works?
#9 ·
Good Luck on this issue...
Crud was causing "My Buddy" Heater from working correctly too...
I cleaned it this morning and it`s working fine...
I`m GLAD I tried it >> BEFORE I need it,
Dennis
Change Gas OFTEN
