It is safe to lean as far as the foot pegs touch the road, as long as the surface is not wet, oily or gravel? :?
True, for some; False for others.amt7565 said:It is safe to lean as far as the foot pegs touch the road, as long as the surface is not wet, oily or gravel? :?
So if the curve is towards the left, you should lean your weight to the right?cbjr0256 said:Sure - but you can corner faster and safer if you haul your ass off the seat a little and lean your weight out inside the turn. The bike will need to lean less to navigate the the same arc at the same speed.
No. If you are turing left, shift your body to the left, so more of your mass is left of center of the bike. This will allow the bike to turn in a tighter radius with less lean angle. Ever see motorcycle racing? The guys hand off their bikes on the inside of the turn so they can keep their bikes more upright and therefore have more traction, allowing for more speed and acceleration.outerlimit said:So if the curve is towards the left, you should lean your weight to the right?cbjr0256 said:Sure - but you can corner faster and safer if you haul your ass off the seat a little and lean your weight out inside the turn. The bike will need to lean less to navigate the the same arc at the same speed.
Yeah, & the racers even hold their inside knees out to the inside of the curve so that their knee pads are scraping the ground. But then they're going around hairpin curves at something like 100 mph, so I'm not going to achieve that kind of scratches on my blue jean's knees.Dan K said:No. If you are turing left, shift your body to the left, so more of your mass is left of center of the bike. This will allow the bike to turn in a tighter radius with less lean angle. Ever see motorcycle racing? The guys hand off their bikes on the inside of the turn so they can keep their bikes more upright and therefore have more traction, allowing for more speed and acceleration.outerlimit said:So if the curve is towards the left, you should lean your weight to the right?cbjr0256 said:Sure - but you can corner faster and safer if you haul your ass off the seat a little and lean your weight out inside the turn. The bike will need to lean less to navigate the the same arc at the same speed.
- Dan
Absolutely!Dan K said:You can scrape those pegs going 15 mph in a parking lot.
Anyway, not saying you should be dragging parts all the time, but it's good to learn the limits of your bike in the event you NEED to know them.
- Dan
Yeah, I'm afraid that when I hear it I'll freak out and pick the bike back up, running off the road.AngryHatter said:Absolutely!Dan K said:You can scrape those pegs going 15 mph in a parking lot.
- Dan
If you scrape without having heard it before you may react badly.
The common reaction. And hard to avoid the first time (or two) you hear it, no matter how prepared you *think* you are for it.outerlimit said:Yeah, I'm afraid that when I hear it I'll freak out and pick the bike back up...
Maybe. It depends a lot on which way you are leaning and which way you are trying to turn......amt7565 said:It is safe to lean as far as the foot pegs touch the road, as long as the surface is not wet, oily or gravel? :?
+1Hondaguy said:Lean into the scrapping side at higher speeds
Away at low speeds to counter balance the bike back upright.
Its never safe to drag bike parts, That would be EXCEEDING the limits of the bike which rarely comes out good on public roads.
Yes, that is probably wise. Find yourself a parking lot that is empty on weekends - usually the industrial part of town has big parking lots & they only have employees filling them up Mondays thru Fridays, leaving them virtually empty on Saturdays & Sundays. Get yourself some old tennis balls (find a Pro and ask for their discards) & cut them in half, painting one half fluorescent orange & the other half fluorescent green, then lay yourself out a track on CLEAN asphalt & practice your turns starting at the slowest speed you can manage & then slow it down even further with each pass. Then, speed it up with each pass, until you can feel the effects of counter-steering (pushing the handlebars in the opposite direction that you want to turn will force the bike to lean into the curve & you'll go around the curve the direction you want to go). Then, once you have the counter-steering down, you can start speeding up even a bit more with each pass until you are pushing harder & harder on the handlebars in the direction opposite the curve, you'll lean harder & harder into the curve, and eventually you'll scrape. But, you'll scrape with the expectation of doing it and, tho it will surprise you, it won't shock you into a jerking reaction.outerlimit said:I'm going to try to do it at a slow speed somewhere controlled so that I can know what it sounds and feels like
Got some tenis balls 2 weeks ago and practiced...David said:Yes, that is probably wise. Find yourself a parking lot that is empty on weekends - usually the industrial part of town has big parking lots & they only have employees filling them up Mondays thru Fridays, leaving them virtually empty on Saturdays & Sundays. Get yourself some old tennis balls (find a Pro and ask for their discards) & cut them in half, painting one half fluorescent orange & the other half fluorescent green, then lay yourself out a track on CLEAN asphalt & practice your turns starting at the slowest speed you can manage & then slow it down even further with each pass. Then, speed it up with each pass, until you can feel the effects of counter-steering (pushing the handlebars in the opposite direction that you want to turn will force the bike to lean into the curve & you'll go around the curve the direction you want to go). Then, once you have the counter-steering down, you can start speeding up even a bit more with each pass until you are pushing harder & harder on the handlebars in the direction opposite the curve, you'll lean harder & harder into the curve, and eventually you'll scrape. But, you'll scrape with the expectation of doing it and, tho it will surprise you, it won't shock you into a jerking reaction.outerlimit said:I'm going to try to do it at a slow speed somewhere controlled so that I can know what it sounds and feels like
That's my practice routine, tho I've not gotten the pegs to scrape, yet. But, I do keep practicing the turns as slow as I can, and I'm getting slower, and faster with counter-steering, and I'm getting faster. But, on the open road, I ALWAYS leave myself room for error, lots of room.
It's always good to have some balls (to practice with)! 8)outerlimit said:Got some tenis balls 2 weeks ago and practiced...David said:Yes, that is probably wise. Find yourself a parking lot that is empty on weekends - usually the industrial part of town has big parking lots & they only have employees filling them up Mondays thru Fridays, leaving them virtually empty on Saturdays & Sundays. Get yourself some old tennis balls (find a Pro and ask for their discards) & cut them in half, painting one half fluorescent orange & the other half fluorescent green, then lay yourself out a track on CLEAN asphalt & practice your turns starting at the slowest speed you can manage & then slow it down even further with each pass. Then, speed it up with each pass, until you can feel the effects of counter-steering (pushing the handlebars in the opposite direction that you want to turn will force the bike to lean into the curve & you'll go around the curve the direction you want to go). Then, once you have the counter-steering down, you can start speeding up even a bit more with each pass until you are pushing harder & harder on the handlebars in the direction opposite the curve, you'll lean harder & harder into the curve, and eventually you'll scrape. But, you'll scrape with the expectation of doing it and, tho it will surprise you, it won't shock you into a jerking reaction.outerlimit said:I'm going to try to do it at a slow speed somewhere controlled so that I can know what it sounds and feels like
Need to go back and try it again because I think I can do a much better job now
