Turn signals light but don't blink
6.5K views 7 replies 6 participants last post by  Lostraven33
Howdy Lostraven33!
Congrats on your new present to yourself...good lookin' ride!
The blinker switch...the switch itself could be gummed up and not making proper contact. The switch is cleanable. It takes a little finesse to get into the switch, but is not hard to do. After cleaning, use "dielectric" grease to re-lube it.
That's the first place I would check...
Then...maybe start with the easy stuff and make sure the bulbs in the blinkers are all good and that they are properly seated in the sockets. The sockets should be clean and not corroded as well.
When you turn on the blinkers, does the indicator bulb light up? That bulb would be something else to check.
Lastly, the blinker relay could have gone bad...unlikely, but possible.
Good luck!
