Draining Coolant (VT500C)
1.8K views 3 replies 3 participants last post by  Redman52
#1 ·
Factory Manaul (December 1985) says the cooling capacity is 16.5 liters 17.4 US quarts.
Huh? What ?
THat is over 4 gallons. Doesnt seem right. The entire volumn of the total space of the engine and transmission and radiator would not be 4 gallons.
Hum... maybe 19 ounces....?
I took out the 8mm bolt the manaul points out (seems more like a bolt to hold on the pump cover), and I drained out maybe a quart and a half and it stopped to a dribble. Poured in a bit more water into radiator, and that came out the drain rightway.. so... seems like I have the proper drain opened.
Any comments .... ?
#4 ·
Was concerend that maybe not drianing the system properly.
My 1983 750 which should be very similar shows coolant capacity of 1.7 liters, 1.8 US quarts.
I now see that elsewhere in the manaulk it says "Total System Capacity 1.8 quart".
THat seems more beliveable.
#3 ·
