I will need a new battery this coming spring. Is the Gel filled sealed battery worth the extra money compared to a standard battery? Anyone have any experience with them?
dave
dave
+1 on that I am very picky on maintenance alsoDepending on your maintenance practices and the brand, yes, I like the gels.
Are they worth the extra money? I don't know, because I'm pretty meticulous about maintaining my motorcycle and cars.
Using this information, maybe my numbers were a little high, but basically we are both partially correct. Natural self-discharge could be from .03% per day or as much as 1% per day, depending on the temperature and storage environment. In order to get .1%-.2% discharge your battery would have to be stored at pretty low temperatures (close to freezing or below). The trouble is that sulfation of the battery plates starts happening as soon as the battery is less that 100% charged, so without a float charger you should only expect a limited use battery (like those in a recreational vehicle) to last two or three seasons at best.Myth: A battery will not lose its charge sitting in storage.
Depending on the type of battery and temperature, batteries have a natural self-discharge or internal electrochemical “leakage” at a 1% to 25% rate per month. Over time the battery will become sulfated and fully discharged. Higher temperatures accelerate this process. A battery stored at 95° F will self-discharge twice as fast as one stored at 75° F.
