I've noticed a few times now, that when i come to a stop and am down shifting through the gears to get into first, OCCASIONALLY i have a hard time going from 2nd to 1st. As in there is some "grinding". I had thought maybe i had made my clutch cable to loose after a re-assembly, but even after i tightened the clutch cable i still got a slip. I'm trying to be very mindful of completely squeezing the clutch handle, so I don't THINK it is me.
I've read that the oil can affect shifting? Do i need an oil change? Unfortunately, it is not a consistent problem, i never know when it will grind going down into first so I can't give you any more info on circumstances.
A friend commented:
Any comments from the forum?
Thanks,
Spencer
A friend commented:
Yes, i'm still moving when this happens - slowing to a stop at a light or stop sign. It is what i was taught to do. It is weird though because it doesn't happen every time.
Thanks,
Spencer
