Hello all. I am the proud new owner of an 1999 Shadow 600.
I bought it from a lady at the coast, so unfortunately has quite a bit of corrosion. Busy stripping the bike to redo frame paint and all corroded parts.
There has been an oil leak for the last 2 weeks at the front cylinder. I thought it was the head gasket. But while stripping today, I saw that there is a small hole on the head. If you look from the front, between the frame and the radiator, you can see (or at least I can...) a small hole (about 1mm diameter) next to the exhaust. This seems to be the source of the oil. Any idea what this might be? Will try and post some pics tomorrow.
Thanks for now.
Thanks for now.
