Anyone ever broke their bike giving it a bath? 97 ACE 1100 with 17k on the odo, 1500 of which I've put on. Never leaked a drop of anything and has performed flawlessly since I've owned it. Washed it this weekend, soap and water. Something came up and I had to move my bike real quick, so I fired it up and noticed it sounded a little odd, but these things spit and sputter when cold anyway. When I go time later I decided to take it up the road for fresh gas, thinking maybe somehow it had gotten water in the fuel. Sounded odd again until I got on the throttle coming out the driveway, ran like a top for the next 3 miles. Guess I was just paranoid.
Filled up, headed back, made it a quarter mile and I lost a cylinder. Pulled off to let it sit for a second, when I tried it again it took forever to crank and, upon firing, started spilling gas and oil out of the bottom of the crankcase. Something was coming out the exhaust, white smoke of some kind. Decided to see if it would make it back, wouldn't stay lit for anything until I wound it up near the rev limit. Backfired then ran just fine until I defueled, lost a cylinder again. Once it did it's sputtering trying to wind up the rpm, it smoothed out and ran fine. Put it on the bike lift immediately.
Then it got weird. Once it cooled, I fired it up, fire on both cylinders, and it didn't leak a drop of anything. Put it down on the stand to check oil, no gas as best I can tell. Fired it up on it's side, back to one cylinder, it leaks about a cup of gas from directly above the stand and a large drip of oil about 4" behind it. There's oil in the tailpipe.
Carbs were my first thought, but that wouldn't cause oil winding up places it shouldn't. Something internal like a ring wouldn't be intermittent. Anyone got a place to start?
