DIY Whitewalls with Krylon Spray Paint IN PROGRESS - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 45 (permalink) Old 07-20-2013, 04:43 PM Thread Starter
OK.. so there's the deal. I've done the paint job, but if I'm having a REALLY HARD TIME WAITING FOR IT TO DRY BEFORE I REMOVE THE MASKING TAPE so here I am trying to distract myself..
So this will either be:
a) A great way to DIY whitewall your tires or
b) How NOT to whitewall your tires
Since I read the Aced-It thread and saw that he painted his tires I've been thinking I should try it. I need a new rear, but the tread on the front is really good, so best case scenario I'm making a tire that I would replace with a whitewall great, and worst case scenario I'm trashing a tire that I would replace with a whitewall. Can't loose.
Aced-it brushed on an Elastomatic (sp?) paint (right Ace?) which research showed to be a kind of roofing paint, but I can only find it locally by the gallon for $60 so .. eh.
I've read around the hot-rod forums and what I found about DIY whitewalls is:
- roofing paint works great
- roofing paint doesn't work at all
- whitewall paint works great
- whitewall paint doesn't work at all
- krylon paint works great
- krylon paint doesn't work at all
So, I reckon the real truth is:
- if you get the prep right it works great no matter what paint you use
- if you get the prep wrong it sucks no matter what paint you use
I always create a better result with a spray than a brush, so I'm going with Krylon. I decided to do all this ON the bike with the front lifted so I can spin the wheel and spray from whatever angle I want.
So, here's the way I did it.. and in a few hours I'll be able to post results of the edging, and by end of day tomorrow I'll be able to post what happens after 200 miles.
Materials:
- Frogtape Masking tape (from ACE Hardware) because it claims to contain pixie dust that reacts to paint and creates a really good edge.
- Krylon Fusion Satin White (Paint Code 2420)
- 5Star 5900 Automotive wax and grease remover
- wire wool.
1) Picked off all the dumb little spikey moulding bits of rubber because they would get in the way of masking tape
2) Washed with soap and water
3) Degreased with 5Star (I'm told that scuffing surfaces can push grease deeper)
4) Rubbed down with wire wool to create a bit of a key. I didn't go at it with a drill attachment or anything because I know I wouldn't get consistency up to the rim and edge line, so fingers crossed what I did is enough.
5) Washed with soam and water again
6) Degreased again
7) Masked the inner rim. This was pretty easy.. just ran my thumbnail along the tape and turned the wheel pushing the edge into the channel between the rim and tire. This leaves the tape sticking up in the air as you can see in the photo below.. which is perfect.. I cut a circle of plastic, and stuck it to the inside of the tape. That was easy and tidy.
.. and now I want black solid rims.. that looks bad ass.
After much photoshopping I decided on how wide I wanted the whitewall. I spun the wheel with a pair of scissors against the tire to create an edge line i could follow with the tape.
9) I sliced in to the tape like this so it I could get the curve nicer. In the end, I had to smooth out the line somewhat anyway with small bits of tape, and in hindsight making a cut ever 3/4 inch would have been optimal for ease and good curveability.
First side done!
Second Side Done!
.. leaving a nice series of tabs of tape
10) Laid a strip of plastic on the tire tread, folded in the tabs and went round again with tape to close up all the gaps.
READY TO GO.
11) First coat. Spun the wheel slowly and went pretty light all around on both sides.
Let it dry for 5 minutes then did the same again.
Let it dry 15 minutes then did a more systematic thorough coat
Let it dry 15 minutes did the same again
Let it dry 1 hour, dropped it off the jack and rolled it outside.
Is it going to be awesome????
I DON'T BLOODY KNOW and it's driving me insane. I have a terrible habit of spoiling really good paint jobs by not waiting long enough before removing the masking and then not waiting long enough to reassemble..
More soon.
K
The story so far in pictures.
Jacking a 1100 ACE video
DIY Krylon Whitewalls
thewump is offline
post #2 of 45 (permalink) Old 07-20-2013, 05:17 PM
tc862011's Avatar
looks good so far
1986 honda shadow vt700c - roxy
tc862011 is online now
post #3 of 45 (permalink) Old 07-20-2013, 05:18 PM
Dauntae's Avatar
Won't Krylon crack with the flexing and stretching the tire does???? Aced it has a tread that he did the same but with a rubberized type paint and it worked well, If the Krylon has issues perhaps you could try it with the stuff Aced it used.
Dauntae
2001 Shadow Spirit 1100 Cobra highway bars Kury ISO grips w custom weighted bar ends ,a VTX headlight and Kury Large ISO pegs but the best addition, Riding bell from Kathy M
I laugh in the face of danger, then I hide until it goes away
The book of John Hopkins map
http://www.travellerspoint.com/membe.../tripid/365293
Dauntae is offline
post #4 of 45 (permalink) Old 07-20-2013, 05:43 PM Thread Starter
Dauntae
We will see. I've heard people saying everything from "it peels off" to "there are tiny cracks" to "it's great"
.. and I've seen exactly the same responses with the rubberized Elastomatic roof paints.. so it's all about prep. I've done a fair amount of paint work and it's always all about prep.
This is well degreased, and a very thin coat but time will tell. This time tomorrow I'll be laughing or crying.
K
thewump is offline
post #5 of 45 (permalink) Old 07-20-2013, 05:59 PM Thread Starter
Couldn't wait anymore.. took off the masking.
LOOKS awesome.. Not going to ride it until the morning though.
Fingers crossed.
K
thewump is offline
post #6 of 45 (permalink) Old 07-20-2013, 06:32 PM
I'm interested to see how it turns out. I hope good because I miss my whitewalls
95 shadow ace vt1100
classic vt1100 is offline
post #7 of 45 (permalink) Old 07-20-2013, 07:31 PM
derekt78's Avatar
Location: Dallas, GA in the metro Atlanta area west of downtown.
Hmmmm.... I really like it!!! Hope it turns out after the ride.
derekt78 is offline
post #8 of 45 (permalink) Old 07-20-2013, 07:41 PM
BootheatsBUGS's Avatar
I have been contemplating white walls on my phantom but I'm no where near ready for new tires. This is great!
1976 KZ400
2001 KDX 220r
2006 xl1200L
2013 Shadow Phantom
BootheatsBUGS is offline
post #9 of 45 (permalink) Old 07-20-2013, 08:05 PM
Best of luck! I hope this turns out well for the both of us.
My reason is because i cant find a C/T with dual walls, and this would be a good fix even if it only lasts a few months.
DBabyBoxen is offline
post #10 of 45 (permalink) Old 07-20-2013, 08:11 PM
RustDeamon's Avatar
looks great so far now lets hope it doesnt just start flaking like the bondo off my truck....
1985 shadow vt700c (under going serious restructuring)
1980 honda cm400t (almost complete need stock battery cover)
1986 yamaha rt180 (perfect except front fender broken)
1982 yamaha seca 400 (Semi-decrepit future, wheelie machine)
1973 kawasaki 350 triple (future restore)
I hated the music why do I seem to be stuck in the 80's?
RustDeamon is offline
spray paint suggestions? gordo2472003 General Bike Discussion 7 02-09-2012 07:58 AM
Spray paint lace? mattman214 General Bike Discussion 11 12-19-2011 06:20 PM
spray paint for customization? Erhrole Technical Discussion 10 10-07-2008 09:25 AM
The New Paint Job - not bad for a spray can andyf80 General Bike Discussion 42 07-22-2008 10:33 AM
Recommended spray paint?? Wassup Technical Discussion 8 07-20-2007 05:33 PM
