Replacing Start/Kill switch assembly
16K views 15 replies 9 participants last post by  aaron_jo
#1 ·
2001 Honda VT750CD Shadow Deluxe ACE
I picked up my new start/kill switch assembly from the dealership today. I was at the shop at work and figured id go ahead and throw on the new assembly. Unplugged the connectors in the headlight cover. I noticed that the connection from the main wiring harness was male, and the wiring from the start/kill assembly was also male (on the new assembly). I thought all the connectors coming off the main wiring harness were female, yet mine had a male. Not being able to get home, i decided to cut and switch the male end on the main wiring harness with the female that was on the old assembly. I carefully went wire by wire and plugged in the new assembly. When I turn the key to the on position, the starter turns over. So something does not match up.
Is the start/kill assesmbly supposed to have a male or female connector? The parts diagrahm shows it as male, yet the assembly I replaced was female.
#3 ·
Male connector has male terminals.
#4 ·
Just did mine in April or so. Just looked at the old one I replaced. Definitly female receptacle at the red connector that plugs into the 9 pin connector in the headlight bucket.
My original starter switch lasted nearly 45K mi. The replacement will out live me!
#11 ·
I have encountered the same on the ACE model after buying 2 so I am hard wiring w/ solder
I plan to move the bars from my risers and rest them on a towel if need be, but most of the wiring is going to be done in the headlight assembly
